Last night I was talking to a buddy of mine and he agreed to let me see how my 94 Firebird would look with his C4 Corvette rims and tires on it. Surprisingly the fronts went without an issue. Everything clears as if it was factory, the issue we hit was the rear wheels. The center lip on the hub is about 1/16th of an inch to large to fit his rims on my car. would going to a disk brake setup change the size of that lip and allow these rims to fit or would I still have to get different rims? thanks in advance
**edit** finally figured out how to move pics from my phone to my computer so here ya go.
Reason: Fixed pictures
Can't hotlink from that webserver, I moved your pictures to our server.
The offset is nicer, and I would certainly say that they are better looking than the factory bird rims of the era, but I wouldn't say you should pick them and stick with them.
A lot of rims require a bit of sanding to slide over the rear hub. My DRs took a dremel and about a minute on the wheel on each to fit them on the rears. Note that I have discs in the rear.
Thanks I didn't know that.
I agree they arent the best looking rim out there but they are a good bit wider than stock and low profile. Ill look into seeing what other rims of the same size will fit.
Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...
