im so pissed off, it snowed yesterday and today and i looked at my car and the stripes are lifting, is there any suggestions on what i should do. it lifted a good half inch on the corners. if anyone can help it would be great.
Vinyl Stripes lifting
Re: Vinyl Stripes lifting
You may want to try a clear silicone or an adhesive with a similar base. Something that could be removed with relative ease without ruining the surface...if needed later on. Also, heat the Vinyl up with a hair dryer to make it pliable before applying the adhesive.
Hate saying it, but it sounds like the body wasn't prepped before the stripes were applied. Could be wax, dirt, or maybe even a dry spot on the back-side of the stripes. In order to do it correctly, they will have to be removed, discarded, and a new set will have to be laid down.sigpic
i was thinking they would have to be taken off and redone. this would be the 6th time he be redoing them b/c of them lifting. do you think the vinyl won't stick to my car or is he just not doing it right?
Originally posted by DaBird19 View Posti was thinking they would have to be taken off and redone. this would be the 6th time he be redoing them b/c of them lifting. do you think the vinyl won't stick to my car or is he just not doing it right?
Originally posted by DaBird19 View Postsome vinyl guy installed them. i thought going to a guy who does this for a living would be able to do it good.
Originally posted by Smoke Panther View Postwhy would you go back to the same guy after he messed up the vinyl job the first time, much less the second, third, fourth, and fifth time?
By the way I have 3m vinyl stripes from ebay on my car, dual 10'' ones running down the middle length of the car and they're holding on OK so far. FIY I live in Canada so we get a dump of snow here contrasting with warm summers :).
WOW, are you serious?
he is doing something wrong
vinal should take years and years and years to come off
i have had the camaro fill-ins on my car on for about 3 years and they are perfectly fine.. i put vinal on another car and its been on for 5 years with no problems
Originally posted by Smoke Panther View Postconsidering I don't do it for a living, and the stripes I put on 2+ years ago are still looking brand new, i don't think "doing it for a living" has anything to do with it. Also, why would you go back to the same guy after he messed up the vinyl job the first time, much less the second, third, fourth, and fifth time?
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...2 days ago
