a lighter hood..some questions - FirebirdV6.com/CamaroV6.com Message Board
  • a lighter hood..some questions
    is there a difference between carbon fiber and fiber glass? if so which is lighter? im looking into weight reduction parts for my car. so if i were to get a lighter hood, how much work is required, and what type of work is required, to take off my old hood and put on a new lighter one? could this be done myself?
    Re: a lighter hood..some questions
    There is a difference between fiberglass and carbon fiber , I think it is 10lbs lighter, but there are alot more options if you go with fiberglass. For mine since I bought my 3" SS hood for $200 off of craigs list, I just had to fiberglass one of the corners that was cracked, real easy to do and fix. Don't know about Carbon fiber how it is to fix. On install I had to sand down the area I fiberglassed since it was hitting when opening the hood so it was pretty easy to fix. I primered it and then had it painted. It was def. ligher than the stock hood. I don't know the LBS. but I would guess 15lbs to 25 lbs. Hope this helps.
      how do i get my stock hood off? and what exactly attaches the fiberglass hood to my car? what tools and whats required to do this besides sanding down?
        The stock hardware was used when I put mine on, I think 4 bolts when the hood is open. You'll see them when you open the hood. If the hood is gel coated and your going to do it yourself, just look up some sanding prep guides and follow the instructions on sandinf it and primering it. Not really hard to do, just time consuming.
          so the stock hood i just take the bolts out and it will come off? and then basically just bolt the new hood back on and tighten the bolts? (besides the sanding)
            yes you could just bolt in a new one, but most hoods wont allign correctly. So you might have to put in some time alinging the hood as well.
              thanks
                will a ss style vfiber hood fit my 02 3.8?
                  if its made for the camaro ss?
                    btw what is the difference between all these names "fiber glass" "carbon fiber" "vfiber"?
                    i know ssm said earlier that fiber glass hood is 10 lbs lighter than a carbon fiber but what about "vfiber"?
                      No , carbon fiber weighs less, and yes you do need to allign the hood once you get it on. I have never worked with carbon fiber so I don't know how you would prep it or sand it for paint. Or even fix it if need be. I know the fiberglass one I got was easy to work with.
                        yes
                        if the hood in question is for a 98+ camaro, and your car is a camaro, yes
                          all i have to say is...if you get an aftermaket hood...get hood pins
                          WAWA-A-HOLIC
                            No hood pins please, not needed. Facotry hareware works perfect. No problems in 2 years. PLus you don't want to ruin the hood drilling holes for the pins.
                              why???
