If I were to change out the Camaro dash to a Firebird dash, what would I need and have to do?
Console swap
Re: Console swap
just swap them out. Im not sure about the ducts for the vents..
they all bolt up the same...MISC: 01 parts. Some interior, T top kit, seats etc.
http://forum.camarov6.com/showthread.php?t=95347
Re: Console swap
door panels are not a direct swap, its an easy fix though to make them work. Basically you cut the mounting tabs off the door and drill new holes.
Re: Console swap
Originally posted by Meatyshells View Postdoor panels are not a direct swap, its an easy fix though to make them work. Basically you cut the mounting tabs off the door and drill new holes.
why change it that much when its designed on the same base...
ArcherMISC: 01 parts. Some interior, T top kit, seats etc.
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
