2002 Trans Am Wheel fit - FirebirdV6.com/CamaroV6.com Message Board
  • 2002 Trans Am Wheel fit
    I got an offer to buy some chrome 2002 Firebird wheels from this guy to put on my 94 Camaro. Now I don't think they will fit because I got some 5 star wheels from a 97 Camaro that I had to hollow out to make fit. Is the Center Hole to small? and can I widen the Center hole to make the wheels go on my Camaro?
    Re: 2002 Trans Am Wheel fit
    I have T/A wheels on my Camaro, and I havn't had a problem installing them much less running on them. Just swap and go.
    I ate a bowl of fail this morning.
    Quarter Million Mile Club
      the wheel should have fit perfectly to begin with, I know there are some funky things in the early fourth gens, never seen or heard anything on wheel sizes.
      But yes they should fit.
        all fbody 93-2002 have the same bolt patterens, same with 5th gen vettes
          The newer 97-02 rims have smaller hub openings than the 93-96's. You just gotta use a dremel and grind it out a tad bit and it will slide right on. Quick an easy to do, only took me about 10 minutes for each wheel. The fronts will go on just fine, it's the rears you gotta worry about.
          <b>1995 Pontiac Firebird</b> || 3.4L V6
