T-top issue - FirebirdV6.com/CamaroV6.com Message Board
T-top issue
  • T-top issue
    Ok, this is DEFINITLY not a new topic, but I heard from someone that all t-tops leak with heavy rain. This kind of made me wonder as I picked up the A and C pillars and the center mohawk from the local scrap yard to start my t-top transformation.
    Is it true, or is he just blowing smoke up my ars?
    I ate a bowl of fail this morning.
    Quarter Million Mile Club
    Re: T-top issue
    they only leak when the seals are bad
    mines fine...
    MISC: 01 parts. Some interior, T top kit, seats etc.
    http://forum.camarov6.com/showthread.php?t=95347
      Re: T-top issue
      mine are fine....just do a good weatherstripping job.
      btw my car has original weatherstripping its a 97 with 150,000 on it and the ttops are ALWAYS baking in the sun
        Re: T-top issue
        Water only comes through mine when going through a car wash because of all the pressure.
          Re: T-top issue
          water has only leaked through my ttops in a touchless carwash cause of the highpressure, and occasionally if my car has been sitting in the rain and i slow to a stop (the water runs down through the cap between the window and the weatherstripping. i plan on re-weatherstripping my car soon anyways. Convertibles from past experience leak more in the rain then ttop camaros do
          Robby
          2001 Chevrolet Camaro 3.8 V6
          |JET Chip|Flowmaster American Thunder|K&N Intake|BMR STB|Spohn Rear Sway Bar|
          http://speed-bros.com/
            Re: T-top issue
            x3 on the occasional wash leaks...it only leaks rarely if i take her to a self-serve wash and use the pressure sprayer, which i'd expect with all that force behind the water jetting out. otherwise, she practically never leaks even in the heavy rains, even in all the elements outside in the parking complex where i have to keep her for now. after i get some decent sfc's i expect what little leaks i have to be gone. '02 ttop 66,xxx btw.
            pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
            gone in body, but not in spirit
              Re: T-top issue
              Thanks alot, everyone. The t-top conversion will start when I get the glass!
                Re: T-top issue
                mine did leak....i just played around with the weatherstripping and it stopped leaking. I wouldn't mind having a leaky top, its worth it. t-tops are awesome.
                  Re: T-top issue
                  that is a pro of doing the convert. yourself. when i did mine i made my seal so tight.
                  she doesn't leak at all. than again she doesn't come out in the rain hahah
                  WAWA-A-HOLIC
                    Re: T-top issue
                    Yep, only in car washes, and even then very very little, and it's an easy fix, unfortunately I locked my T-Tops then lost the key, so until I can get a key made, they will leak slightly in rare occasions.
                    1996 Chevrolet Camaro
                    1995 Buick Park Avenue Ultra
                    --Appearance Moderator--
                      Re: T-top issue
                      Mine leaked at 37k miles....
                      <a href=\"http://photobucket.com/albums/c368/rallysportchic97/\" target=\"_blank\">http://photobucket.com/albums/c368/rallysportchic97/</a>
                        Re: T-top issue
                        And like some have said, if they ever do leak, it's easy as cake to adjust the weatherstripping or add a bit of adhesive wherever the leak is coming from and get rid of it. The design is so much better than 3rd gens it's ridiculous.
                        • Andy H
                          Transmission removal help!!
                          by Andy H
                        • 2.8 Bird
                          Abs inop
                          by 2.8 Bird
                        • fishin
                          by fishin
