I found the info on how to make the door, but the pictures didn't show how to disconnect the lines going to the pump, or how to get to them. Any help and pictures would be a great help. Do you need to make the access panel larger?
Fuel Pump Trap door
Re: Fuel Pump Trap door
they have a clip on the hoses, I used a screwdriver before when I swapped pumps
I did the trap door , glad I did too. It makes it so much easier to swap the pump, and I made a cover to go back over it. I also cut a little more down by the disconnect lines so it was alot eaiser to get those off also. 1 of the best top 10 mods to do for the F body.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by 3.4grapeofwrath View PostDitto on that mod. What a time saver if you like to bust your balls you can drop the tank. If that's doing it the right way then I'll do it the wrong way everytime. By the time you drop your tank my pump is already out.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
If you search for my user name on this topic, you'll find some 99+ pictures. The earlier models have different tanks and locations.
I did the cutting (I was extremely careful on the left side not to cut too deep), bought the pump and then took it to a mechanic who to in in for me - well worth avoiding the "I don't know what to do now" factor and having gas sloshing on my hands.
The mechanic only charged me a small amount becuase it was so easy.I solemnly swear I am up to no good.
http://forum.camarov6.com/showthread...ight=fuel+pump
This is for 99+.
For 98 and earlier, do more searches.
98 f bodies = transition year = everything is a mess.I solemnly swear I am up to no good.
All the cutting outlines are the same, just if you want more room for the disconnects, cut more by the drivers side, just be careful and like stated not cut deep on that side until you can see where your cutting. For my 96' when I put in my walbro 255 high flow I ditched the bucket used 2 bigger size hose clamps to clamp everything together and the connectors where plug & play. Pretty easy. Well worth cutting the trap door ,plus about a 5lb weight reduction from the heavy @ss metal.LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Whoa I think I may have to do this repair as well. Im thinking of going with the cutting a whole deal. But I got a quick question. When I turn the ignition on, I hear a 1-2 second whine coming from the back. Im guessing thats the fuel pump.
Well to make things short my car isn't starting. The power is fine, it turns on, but just wont turn over. Does this sound like the fuel pump went out although I hear that whine?
Trap door FTW.
I wouldnt waste the time dropping the rearend and the tank. Get a fuel line remover from any autoparts store (around $8) for the fuel lines.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
