should be fine, but not sure about the tires.. (not a tire guy)
as far as the deal... Yeah.. real vette rims, $500.. hella deal. I mean even if you cant use the tires.. as long as the tires have life still in them, you could get some money back out of that.. But tires for those rims, to mount on your car is not cheap, so thats something you would have to look into once someone can telly ou more about the rubber itsself.
ok so i figured out that the back tires are about 1/2 inch taller then the camaro stock ones and the fronts are about 1/2 inch shorter so that shouldent be a problem but will this screw up my abs and traction control? i think it will but does anyone know for sure?
