I was recently involved in a small fender bender in a parking lot. A toyota matrix ran into me at the front driver side headlight area going about 5-10MPH.Damaged the fender, bumper cover, and hood. I got a new stock hood from a local guy parting out his car, and i bought 2 new hinges from the dealer, but i can't seem to get the hood to fit right. On the passenger side, theres a widening gap which is about 1 to 1.5in. at the front. on the driver side, the hood sort of overlaps the fender. I've loosened all the bolts and i've been trying to straighten it... can't seem to do it though. Any suggestions?
Need help aligning hood
Re: Need help aligning hood
wish i could help you but....
mines not aligned right either. no matter how i try i would loosed the bolts and sort of guide it along the fenders to get a good fit and when i bolt it up either its worse or doesnt bolt up right at all. lol i guess i can use the help too
I had problems with mine lining up to when I did the 98 front end conversion. I had a machine shop lengthen the bolt hole in the hood bracket (the one that bolts underneath the hood) into a slot so that the hood had more play to slide around. Kinda hard to describe without pictures, I'll try and take some tomorrow so it'll be easier to understand.
give this a look over and see if it helps
http://armorysound.com/forumsadv/showthread.php?t=27
Originally posted by screamin 99 View Postgive this a look over and see if it helps
Originally posted by truekoa View Postdid anyone try that guide? how much do you have to widen the bolt holes?
Originally posted by screamin 99 View Posti have been searching all over for a hood alignment writeup and i found that link on ls1tech. it does say to open the holes up a generous amount to give you more room to play with. i plan on using it to put on my ss hood i just picked up ($200 btw:rock: from ls1tech)
thanks!
Originally posted by truekoa View Postnice! mine was like 300 locally. when are you doing yours? could you let me know how it turns out, i feel uneasy having to widen the holes without knowing exactly how much.
thanks!
