Any one know how to have low and high beams on while still being able to have the fogs on... Gotta 97 Camaro RS Y87. Ive seen pictures of people with all of the above on at the same time... any one know how to do it or could direct me to a write up it would be greatly appreciated. Thanks for the help guys!
High Beams and fogs on at the same time?!
Re: High Beams and fogs on at the same time?!
how to make your fog lights stay on with your high beams..
Tools Needed:
Flat Head Screwdriver
Philips Head Screwdriver
Wire Cutters
Parts Needed:
Appx. 18" Of Wire
Electrical Tape
Purpose:
Wire fog lights to stay on with hi-beams.
How - To:
Step 1
Disconnect negative battery terminal. Open fuse box under the hood on the drivers side (near the air box). Find the fog light relay (Block H).
Step 2
Remove the fuse box from the frame. You will have to push in the 6 plastic retainer clips that hold down the box. Pry up the box.
Step 3
Look on the bottom of the box under the fog light relay fuse. You should see 4 wires (orange, yellow, purple, light green).
Step 4
Cut the light green wire. Take the 18" wire you have & splice it to the wire coming OUT of the fuse box. Take this wire & ground it to one of the bolts holding the fender on the car. Make sure the wire doesn't interfere with anything else under the hood.
Step 5
Tape the dead end of the light green wire coming out of the harness.
Step 6
Reassemble (the box snaps into place) & test lights.
Step 7
Note : The light on the fog light switch on the dash still goes out when the hi-beams are on.
__________________
awsome thanks for the help man. hopefully it works out well. one question though. you say cut the light green wire. this wire is now dead coming out of the box. got that part. But splice the wire coming out of the fuse box and ground it? Which wire? Arent there a ton of wires coming out of the box? Might be dumb question.. its 12 right now and i dont feel like going out and looking hahaLast edited by 97RSRPV; 03-12-2009, 02:19 AM.
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...2 weeks ago
