door hanging low. - FirebirdV6.com/CamaroV6.com Message Board
door hanging low.
  • door hanging low.
    my doors on my 1996 Firebird seem to hang low. and when i close them, they kinda hit the body of the car. Also, the driver door squeaks a lot! I wanted to know if/how i can fix them..new hinges?
    Re: door hanging low.
    i'd say simply check any loose bolts or anything around the hinges to start. obviously something isnt tight.
    and the squeaks can be easily fixed with a little grease, lubricant, or just spray some wd-40 right in the hinge on the roller and swing the door a few times until it sets in and you stop hearing it...just wear 'n tear.
    pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
    gone in body, but not in spirit
      You can lift up on the door...and have a buddy try to tighten the hinges. I did that with a ladder and some ratchet straps. Worked pretty good....still get a little squeak not as bad though.
        ill try tomorrow..thanks!
          its a pretty common problem i hear, cause the doors are so long and heavy they sag after while
            tighten i think its 2 or 3 big hinges near the door jam toward the front of the door, good luck! had the same issue with my buddy's mustang
            Robby
            2001 Chevrolet Camaro 3.8 V6
            |JET Chip|Flowmaster American Thunder|K&N Intake|BMR STB|Spohn Rear Sway Bar|
            http://speed-bros.com/
              lol ive added "spraying WD40 on hinges" to my regular maintenance schedule
              1999 v6 Camaro M5
              Automatic to Manual converted
              Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
              !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
                haha good! been doing it for years on mine. works great on squeaky doors in your house too lol.
                  is it recommended to remove the door completely?
                  Also, I have recent paint about 2-3 months old, will WD40 cause any damage at all?
                  1998 Chevy Camaro 3.8
                  1997 Chevy Camaro Z28 - SOLD 7-23-2011
                  1996 Chevy Camaro Z28
                  2001 Pontiac Firebird Formula
                    welcome to the world of the 1200 lb door
                    WAWA-A-HOLIC
                      dont think that's very necessary. and your paint should be fine, just use what little is needed and wipe away any extra.
                        The extra weight of the paint is what caused the dors to sag.
                        As Kristen said, the big doors on our cars are HEAVY!!!
                        I solemnly swear I am up to no good.
                          I used PAM once when I was out of WD-40... now I keep one of those little mini bottles of WD-40 in my console...
                          Custom interior...
                          TEAM NoVa
                            so i tried to tighten the bolts. They were pretty tight, so i couldnt really do much, BUT the bushing on my driver side door looks like its bend...
                            (Its very dirty in there i know :cry:)
                            Is there a way i can change it out? And does anyone have a part number?
                              http://cgi.ebay.com/ebaymotors/DOOR-...Q5fAccessories
                              Custom interior...
                              TEAM NoVa
