i want my speedo and tach to be more white than yellow so if i just swap out the 194s that light it up with some white led 194s will that take care of it? or do i need to split it all apart and sand down behind the gauges?
want my gauges to light up more white...
Re: want my gauges to light up more white...
Originally posted by masonvonritchie View PostLED's will definitely help you out. I replaced the 194's with blue LED's and even that is brighter than the regular bulbs. So a set of white LED's will surely brighten your gauge cluster up.
you got any pics?
Originally posted by bigbrian442 View PostRemember LED's can't be dimmed, so if they are too bright you have to live with it.
Rob: The lack of contrast is because of the fairly drastic difference in power required to light up an LED in comparison to an incandescent bulb. An incandescent bulb might take 5w to power to it's peak performance level, whereas a comparable LED might require somewhere in the neighborhood of .15w. Since the dimmers on our cars are made for dimming incandescents, they are not set up properly for dimming LEDs.Last edited by TheGr8Schlotzky; 08-19-2009, 11:58 PM.
Originally posted by savagecamaro96 View Posthow do you like the blue ones?
you got any pics?
My white face gauge over lay has the red parts light up with the stock dimmer switch and also dims the blue too. the white looks great during the day and outstanding at night. I can't remember how long it took me or when I did the install but I know it was a pain. My gas mile countdown never worked after I did the white face gauges. Damm it.LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
i got LEDS in my mr2.l looks great. i could dim them no problem. im planning to do the same to both camaros
http://superbrightleds.com/specs/bulb_specs.htm
you should aviod leds that all face the same direction because they will cause hot spots
As far as whether they dim or not, I guess it just depends where you get them from. I got a set of blue LED's from superbrightleds.com for the HVAC that would dim, but I had to take them out because for some reason after I put them in, my turn signal bulbs kept burning out. But I got a set for the gauge cluster from ledvault.com and they don't dim.
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...6 hours ago
