Sooooo I found a rear for $350. It's out of a 94 Z, so it has discs, posi, and 3.42 gears, and has 65K miles on it.
I have a v6 95. How hard would it be to swap it into my car? And would the gas mileage be much worse since the gearing is going up?(as far as i know v6's have 3.23 correct?) Would everything just match up and bolt on no problem? I'm just wondering. If it's an easy swap I might just do it.
Thanks guys!
that sounds pretty good. you have the 3.4?
i think it should be a direct swap, i'm doing one right now actually. just make sure it doesn't have traction control and your dont etc.
thats kind of expensive, i got the same rear for about 200$ but then again that has pretty low miles on it.
