Gear Swap - FirebirdV6.com/CamaroV6.com Message Board
Gear Swap
  • Gear Swap
    I'm thinking about doing a gear swap, I have 3.08s in my rear end now, and want to go up to 3.42s. How hard is this procudure? What exactly do I need? etc. Is it better off just paying someone? or not doing it at all?
    Re: Gear Swap
    read end stuff is something you let a pro do, to be safe.
    for gears, I believe 3.42 is still a 2 series carrier so you just need the actual gear for the swap.
    might as well add a lsd unit while you're there. you can also use a rear end installation kit.
    you can read more about it here http://mods.firebirdv6.com/drivetrain.html
    select gears on the left side.
    also take a look at this site
    http://www.thunderracing.com/catalog...&vid=5&pcid=68
    thats where i bought my items from when I upgraded my rear end.
    you can choose from different carriers, gears, oil addictive, and it comes with rear end cover and studs to strengthen ur investment. the package doesn't include a lsd unit though, so you will have to buy one separately.
    once your done with the hardware, remember you still need a tune to properly adjust your speedo to match your new speeds.
    hope this helps.
    1998 Chevy Camaro 3.8
    1997 Chevy Camaro Z28 - SOLD 7-23-2011
    1996 Chevy Camaro Z28
    2001 Pontiac Firebird Formula
      Re: Gear Swap
      Yeah I know that it would need a 3 series carrier, but I read that you can put a gear spacer in to avoid the carrier change..but is there a write up on how to do just the actual gear and pinion swap?
        Re: Gear Swap
        Richmond sells one. Try searching youtube.
          Re: Gear Swap
          I've never seen an actual spacer, but Strange, Richmond, and probably some other manufacturers make a thicker ring gear to use with a 2 series carrier.
          -<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
            Re: Gear Swap
            http://www.summitracing.com/parts/MGR-075050/
            Motive makes one for the 7.5/7.625. But for the price you should just buy the gear set made to fit the 2 series carrier.
              Re: Gear Swap
              well the highest gears for a 2 series are 3.08s, which is what i'm currently running stock..anything higher requires a 3 series carrier or a gear ring spacer.
                Re: Gear Swap
                http://www.thunderracing.com/catalog...&vid=5&pcid=67
                there are some higher gear ratios that come with a two series carrier.
                scroll down to pro street gears.
                  Re: Gear Swap
                  Or a 3 series gear set made to fit a 2 series carrier. The spacer ring is made into the ring gear.
                    Re: Gear Swap
                    you mean " lower" gear ratio's.
                      Re: Gear Swap
                      Is it possible to do a gear swap on a car without LSD?
                        Re: Gear Swap
                        Yes...
                          Re: Gear Swap
                          Yes but why bother? Unless you are going to go to something like a 2:73 to improve gas milage on the highway, it is pointless. The lower gear ratio you go (3.42, 3.73, 3.90, 4.10, 4.56) the easier it is to spin the tires...you would never get the potential out of you're car if you didnt put the posi unit in...infact, you would probably be slower due to lack of traction.
                            Re: Gear Swap
                            Agreed. My car is currently back in the shop having the 3.42/Torsen unit reset for proper backlash. But the brief time I did have it to drive after the initial install was no comparison to an open diff and 3.08 gears. Do it right the first time with a limited slip differential and some good gears. Don't forget to get the proper ABS reluctor ring if you do end up getting a series 3 differential.
                            '99 Camaro
                            '04 Saab 9-3 Aero
                            '90 Audi Coupe Quattro
                              Re: Gear Swap
                              Alright, that's what I figured, just needed confirmation. Time to look for a rearend.
