Accidently started the car in third today. Jolted the whole car, and now my clutch pedal is slightly loose. It's very easy to push in about halfway, then pushes in normal after that. Still drives, but the clutch engages just as I let off the clutch. Any ideas on how to fix?
Clutch pedal pressure
Re: Clutch pedal pressure
"you started the car in third" meaning you started driving in third instead of first? or you bypassed the clutch and have a remote start or somthing close to this? hahah (its possible)
Ive takin off in all gears. i dont see how this would have caused a problem. I know a few viper guys that leave the line in second gear all day long.
Any funny info you would like to add? but my guess would be to bleed it a few more times and see if you can find a leak. If not i would assume its the master or slave
