Does anyone know if a rear end from a 2000 z28 will go into a 1995 to 1997 v6 fbody?
1996 to 2000 z28 rear
Re: 1996 to 2000 z28 rear
The rear end will physically fit. The gears and brakes will most likely be different (maybe that's what you're going for?). Also, depending on the rear, the ABS systems may be different.
Do a search in the forum, there's lots of good info in here.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
^ Yes you'll run into problems if it is a 4 channel, your ABS light will come on and your ABS won't work. You'll need a 3 channel thats what I have heard.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Already figured out its a 4 channel. And i know how it fix the issue. The douche that sold it to me told me it doesnt have traccont. and it totally does, so after I fit the brake lines from seperate to one and splice the wires for the ABS to the old plug it should be gravy.Last edited by Watazz; 09-17-2009, 11:18 PM.
http://www.funkz.net/firebird/firebirdmod10.htm
^ this has good info for the rear end swaps. he says all the plugs are the same, which isnt true, but with an old plug and sauder should be pretty easy to splice the wires.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
