Is there anyway to swap the manual tranny in my camaro from a 5 speed to a 6 speed? I can't find any bell housing for it or anything
t-5 to six speed?
Re: t-5 to six speed?
I believe I asked this same question on here a long time ago... IIRC what I was told was that you'll need a bellhousing adapter plate... a custom length input shaft... you'll need to modify the interior because shifter will sit further back in the car, and you'll need a custom driveshaft...Rebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
Custom interior...
TEAM NoVa
Just do a search, this question has been asked a lot.1997 Chevrolet Camaro
to make it simple, yes it is possible..
but unless you have extensive mods to your engine it will be HELL to drive, its about the same as starting out in 2nd gear all of the time.. the v6 doesnt make enough power to do that without slipping the clutch so bad it will need to be replaced every 30k miles.. and that is on flat ground.. hills wouldnt be very fun trying to start out unless there was some very short gears in the rear
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
