Hey everyone, will an axle outta of a 1989 Iroc-z fit in my 97 rear? Thanks
Axle...???
Re: Axle...???
the housing for a 93-02 will fit your 97. the problems you can see is if you have drums then for a 98-02 V6 or 93-02 V8 you will need to swap to disk's. ( you should do it anyway) and the later year rear ends that used a 4 sensor( 4CH) ABS system will give you issues. if you pull from a car with a A4 it wil have a 3ch system like the older year cars. hope that helps. its what i ran into with my 94 bird getting a 00 T/A rear.
Re: Axle...???
Originally posted by A fireman View Postthe housing for a 93-02 will fit your 97. the problems you can see is if you have drums then for a 98-02 V6 or 93-02 V8 you will need to swap to disk's. ( you should do it anyway) and the later year rear ends that used a 4 sensor( 4CH) ABS system will give you issues. if you pull from a car with a A4 it wil have a 3ch system like the older year cars. hope that helps. its what i ran into with my 94 bird getting a 00 T/A rear.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Axle...???
You might also encounter a slight issue with the wheels (depending on what you have). The raised flange on the outer end of the axle (the hub) is very slightly larger on the earlier models than the later ones. Factory wheels off the later models (98+) will not fit over the center flange on earlier axles without some grinding. You don't have to take off much, and this grinding will not affect the wheel at all, since it is centered by the lug nuts, not the hub. Aftermarket wheels shouldn't be affected.
Also, not all later model cars had a 4 channel ABS, and not all A4s had a 3 channel. If you're looking at the (donor) car, you can either look inside for a traction control (or ASR, I think) switch- if it has traction control, it has a 4 channel ABS; or look at the ABS block under the hood. If there are 6 brake lines in it, that is a 4 channel system, if there are 5, it is a 3 channel system. If you're only looking at the axle, just look for a splined ring at the end of the axle near the hub to indicate that it is a 4 channel axle. No ring is a 3 channel axle.
With all that said, a 4 channel axle will work in a 3 channel rear as long as it has disc brakes. I doubt the reluctor ring would clear inside drum brakes.Last edited by Skinny; 11-19-2009, 04:45 PM.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...13 hours ago
