axle question - FirebirdV6.com/CamaroV6.com Message Board
axle question
  • #16
    Re: axle question
    http://forum.camarov6.com/showthread.php?t=98484
    See that thread. Read and see :D
    Oh, and that damage was a week after installing a Timken bearing and seal. Read on and see how the second Timken did with the new axle.
    98 Camaro 3.8 M5 Y87 | 99 Camaro LS1 Z28 T56
    • #17
      Re: axle question
      wow, thanks.
      I will stay away from them and either get one from napa or advance
      • #18
        Re: axle question
        Originally posted by cam98aro View Post
        wow, thanks.
        Welcome. I dont want anyone to go through the hell I did.
        And again your bearings may be fine. Might just need axles.
        Are you leaking any oil from the seals?
        • #19
          Re: axle question
          nope, nothing
          if i am taking the axles out, i might as well replace the bearings. My car has almost 150,000 miles on it, so i think i should do a bit of preventative work on it.
          when your axle was damaged, what did it sound like?
          Mine sounds like really loud road noise, or rusty rotors/drums grinding against the brake pad/shoe
          it seems to be the loudest at around 25-35mph, but it is pretty loud on the highway
          • #20
            Re: axle question
            nope, nothing
            Mine sounds like really loud road noise THIS, or rusty rotors/drums grinding against the brake pad/shoe
            I tried to find my original thread that had me attmpting to explain the noise, bot no avail. Mine was like a whiiiiir whiiir whiiiiir, mine was loudest around 40 I think. I still get some harmonics around 65 though :(
            Also think of this; if your axle is worn then it will ride at an angle. Which will cause your rotor to ride at an angle to your pads. This is why I wasted $60 on a new caliper.
            • #21
              Re: axle question
              hey guys, i finally got around to doing my axles today, and i found my noise:
              the passenger side axle was pitted pretty bad, the drivers side looked a tiny bit worn, but since i bought two used axles, i just used both.
              the car is so quiet now, its amazing.
              i bought NAPA bearings (they are torrington bearings, which are the same as the gm ones... and also made by timkin) and i bought some gm seals, they were only $12 each, which isnt out of line, and from what i hear about other seals (timkin) i didnt want to mess with having to take it back apart again.
              i was a bit mad because my cheap harbor freight bearing puller i bought for my pilot bushing snapped so i had to rent a slide hammer from advance
              somehow my spider gears fell out so i had to spend a few minutes trying to figure out how they go back in as i have zero differential knowledge
              thanks for the help though, im glad the problem is fixed
