bolt in or weld ins? relo brackets are always a worthwhile mod on our cars. Nice purchase
I went with the bolt in bracket. Mostly because the car is just mildly modified, I can install them myself, remove them if they don't work, and have them welded later if they do work.
Basically, bolt-in give me all the options I need.
i went with the bolt-in brackets for mine then after i installed had them welded in place once i drove and made sure it was on the right setting. definitely made a difference, especially since i'm lowered.
I forget the brand of my relocation brackets but I just make sure their parallar to the ground like this ----------- , if it is up higher more wheel spin pointing down you'll get the wheel hop. I still like my poly bushings , never had any problems , noise , or any binding. They were the best investment for my car and I have all poly on my car and 1 rod end on the front lower A arms and no rubber bushings left any where on my car. I love it for DD and getting on it off the line and cornering. Also if you want zero traction problems UMI tunnel mount TQ arm is the way to go , so people say they decrease handeling but I just notice a increase in traction from dead stop and coming around corners.
Today I put the car up on the stands to install the relo brackets when I grabbed the lower control arm and WOAH! Those bushings are squishy! I could clearly see the rear bushing, and I can easily twist the control arm with my hands as the bushing does.... not much.
So I ran out and got a set of Moog bushings, and will put those in first, then see if the relo brackets are still needed. Don't have enough time to actually install the bushings today, but they sure look better than the hollow version that is in the car.
This may also be why I didn't have wheel hop in my 96 Camaro V6. I ordered a suspension/handling package that may have used the solid bushings.
