I took the differential cover off the back of the axle housing and there is a speed sensor reluctor wheel next to the ring gear. The 2002 Pontiac Service Manual (Volume 1 of 3) indicates that the rear is a non-traction control rear. Also on the outside of the ham there is a speed wheel sensor mount in the top of ham portion of the banjo just above the reluctor wheel. However there is a TCS (traction control switch) in the floor of the console (what does it do).
The Pontiac manual say a standard differential case cannot interchanged with a limited slip differential case. Also that a traction control rear ha the reluctor rings permanently attached to to each drive axle.
Will I have possible problems with readings from the speed sensor because of the different size of the reluctor ring from a 3.08 (Series 2) to a Series 3 carrier?
I’m looking to convert this basic coup Firebird from a 3.08 standard rear to a 3.73 limited slip.
Any Ideas?
Any Ideas?
