Bent axle - FirebirdV6.com/CamaroV6.com Message Board
Bent axle
  • Bent axle
    :rant:so my F***ing passengers side axle is bent, the one that has been leaking constantly. Not sure how it happened but it did. Let me know if any of you guys have one or know anyone that might.
    Rear end cam out of a 2000 ss 3.42 lsd
    Re: Bent axle
    also has traction control. Does anyone know if I can use an axle W/o TCC? I am not using the TCC
      Re: Bent axle
      traction control axles use a reluctor wheel. I have an axle from my drivers side when my passenger side decided to get pitted.
      the axles are interchangeable for the driver or passenger side and for traction control, you just need to put the reluctor wheel on
        Re: Bent axle
        So you have an axle that came out of a rear without tc? And from what I understand I just need to put my reluctor wheel on it. Will gear ratios and whether it is a v6 or v8 make a difference?
          Re: Bent axle
          if the rear is out of a 2000 like you say, then yes, it should work
            Re: Bent axle
            Hmm alright I will be in touch thank you
