Clutch pressure line - FirebirdV6.com/CamaroV6.com Message Board
  • Clutch pressure line
    So my stainless line to the slave cylinder blew a few days ago. GM discontinued it along with all clutch parts for the T5 V6 car. Bought a master cylinder from Advanced Auto and it does not come with the pressure line just the reservoir line for fluid. Any one know where to find one besides this one or a part #? $90 seams steep to me.
    http://cgi.ebay.com/ebaymotors/95-02...Q5fAccessories
    Re: Clutch pressure line
    That's the only one I was able to find too, I looked on ebay, summit, and jegs. I thought they came with the master cylinder. If you decide to buy that one you can do the clutch line mod. http://www.chevyhiperformance.com/ho...021/index.html
    1997 Chevrolet Camaro
      use the old one i had to be carefull not to crack slave knocking pin out
        I can't use the old line as it has a hole in it...the master cylinder is not bad but since I have purchased one I might install it.
          Thanks espey. Might as well do the mod since it will be out. They are supposed to come with the master but none do. Just got the part # from GM gonna search around.
            Well I cant find crap so I guess im gonna break down and buy the line off ebay.
              Got the line today. 1/8in drill bit wont fit so I used 7/64 which is a step down. I don't know about anyone else but there seems to be no restriction in this line.
                If it aftermarket, it may not have the restriction. I would bet that it wouldn't.
                Raven
                  It's maid by centric parts
                    found it for $53 if anyone ever need one..i knew the guy on ebay was charging..its at the bottom of the page..http://www.clarksdiscount.com/produc...-+Flywheel.htm
