Im stumped. Ive got a new clutch, pressure plate, slave cylinder, replaced the clutch master cylinder twice and im still losing pressure. Somewhere, im losing fluid and then due to the absent fluid i lose pressure. The last thing i can think of would be the clutch line. Can anybody help me out here??
Losing clutch pressure
Re: Losing clutch pressure
Is your bleeder valve closed??? And if so, did you bleed ALL the air out of the line???1997 Chevrolet Camaro
