My car has been making a noise in the rear. It sounds like tire road noise and like a wheel is wobbling or something. I have tried two different sets of wheels. I now have the factory wheels with brand new tires and it still makes noise. It rides smooth and I have looked everything over. Could it be bearings?
bad axle bearings?
Re: bad axle bearings?
Originally posted by Andy H View PostMy car has been making a noise in the rear. It sounds like tire road noise and like a wheel is wobbling or something. I have tried two different sets of wheels. I now have the factory wheels with brand new tires and it still makes noise. It rides smooth and I have looked everything over. Could it be bearings?
Are you getting vibration when crusing or at a stop?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
no, no vibration. the brake pads are fairly new. I jacked up the rear and was pulling on the wheels, I get a little bit of movement when I pull in and out on the wheel. Is that normal?2000 Camaro 3.8 v6 M5
Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
Originally posted by Blizzard242 View PostYeah, there will be a little in and out movement with our C-clip axles. Is the noise like.. woo woo woo woo..? lol it's hard to describe via text.2000 Camaro 3.8 v6 M5
My fronts are doing that.. I thought it was just my tires but I've been wondering about them lately. They've been doing it for a while now and haven't seemed to have gotten any worse.
However, if you do have to change your rear bearings it isn't very hard. The only special tool you'll need is a slide hammer.
Btw, what kind of rotors do you have?
TEAM C6V6
In the back, I still have the stock rotors. They are getting thin so I'll have to replace them soon. Up front, I have kvr blanks.2000 Camaro 3.8 v6 M5
They have those "repair kits" What they are is.. just a set of bearings with a sort of spacer to make the bearings ride on the axle at a different point in case the original area was damaged. Someone from autozone sold those to me not knowing any better, and I didn't know any better either but they're working just fine. I was pulling my hair out trying to find this "clunk" after I changed out my differential when it was just a bolt on the panhard bar not torqued down properly.
TEAM C6V6
That's making me wonder because I'm getting a slight wobble feeling and I had my differential and gears changed couple thousand miles ago.Wait, Is that a V6 or V8?
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...9 hours ago
