the th350 crossmember made by umi can be easly modified to fit the v6 manual with 1le and poly trans bushing with no spacer. ill have pictures up lat in the morning. only took about 3 hours to figure it out( i used the torque arm relocation kit.) all you have to do is drill a new hole for the transmount in the cross-member and cut off the excess metal on the end of the mount. i can't wait to test it out but will do so tomorrow.
th350 transmission for 98+ fbody
Re: th350 transmission for 98+ fbody
here are some pics.
i noticed a some vibration but im sure its all from the poly trans mount because the vibrations change per rpm and not speed. i made sure to test that by getting up to speed and letting the car coast in neutral and when in neutral there are no vibrations. so i think this piece is a success. just wanted to share with you guys so others can try this out if they want to relocate their torque arm or jus not have a spacer on their 98+ f body.
