Today I had time to get my trans out of my 2000 to see what's wrong with it, I know its not the slave or a throw out bearing, I'm thinking its a bent rod. So I unbolted the trans from the bellhousing and it will not come out. There is no bolts left in, everything is disconnected but she just wont come out. Any ideas? Or dose the bellhousing have to come out as well? Im stumped and frustrated :rant:
Trans WON'T come out.
Re: Trans WON'T come out.
Slave needs to be unbolted too. Gotta pull the bellhousing off too.1997 Chevrolet Camaro
Do these transmissions have dowel pins for engine alignment, just curious?Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
Originally posted by SixShooter'00Camaro View PostToday I had time to get my trans out of my 2000 to see what's wrong with it, I know its not the slave or a throw out bearing, I'm thinking its a bent rod. So I unbolted the trans from the bellhousing and it will not come out. There is no bolts left in, everything is disconnected but she just wont come out. Any ideas? Or dose the bellhousing have to come out as well? Im stumped and frustrated :rant:sigpic
the transmission wont come out unless you unbolt the bellhousing because the slave is bolted to it through the bellhousing.
you can put the trans bolts back in and disconnect the bellhousing. you are going to need a ton of extensions though to get the top bolts out
Bellhousing needs to come out with transmission. You need to get all the bolts the top 2 are not that bad just get a wobble extension for the top 2 bolts and a couple of extensions to bring it down maybe 2 feet max.
Just go to harbour freight and buy a pack of extensions and a pack of wobbles probably less then $15. Even after that it is still a pain. The dowels are on the 2 bolts just below the top ones.
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...12 hours ago
