I'm going through the install in my head. I have the mount and poly swaybar bushings, hopefully they'll work fine. What are we supposed to use for the stud to connect the mount to the cross member?
Installing poly transmission mount
Re: Installing poly transmission mount
Theirs a write up on it in the how to's. Pretty easy.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I just opened the how to for the poly mount. Works fine.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
iGoRa's site is down for good. Try this write up instead.
http://forum.camarov6.com/showthread.php?t=63742'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
Got done with the install today, I had to trim down the crossmember quite a bit. It's all good now, took me about 3 hours to do (I'm a slow worker). Shifter doesn't bounce around at all anymore, but vibration like a motha whenever I'm accelerating. I used poly sway bar bushings, hopefully they'll hold up.
I used stock rubber bushings and their alot more forgiving. No vibration with the M5 or A4.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
either one would be my guess.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...11 hours ago
