need a better clutch. - FirebirdV6.com/CamaroV6.com Message Board
  • need a better clutch.
    hey guys a i have supercharged 97 camaro and i was wondering what are the limits of a good stock clutch and some of the aftermarket clutches available for 96 to 02 t5 camaros. my clutch holds up fine and i can give it wot while in 5th and it will hold. just not while racing. so for a limit of around 350 hp what do they have in the market?
    Re: need a better clutch.
    A Spec 3 will hold up well, your T5 will probably break before the clutch slips.
      whats the T5's weak point? my input shaft is very noisy as is and im planing on staying on street tires. ive notice its rated for 300 lbs of torque from factory but staying away from sticky tires should help. im running a stock ls1 aluminum shaft so hopefully that fails before the tranny.
        T5 is the 3rd gear breaking.
          I would honestly say, keep getting OEM clutches, maybe yours is just worn. I would much rather replace clutches a few times and coin up for shattered trans's.
            Go with a spec.... I just pit an exedy in... It's a good clutch but I see it slipping under extreme co.ditions.
            My last 2k camaro.... My wheels slipped, got better tires(still street) fixed spin, 10th bolt went bad fixed it, then my clutch slipped. Fixed that with a spec 2 and new hydraulics and flywheel(BTW get a new flywheel) go to track.... rev up for launch... Snapped The output shaft on tranny. And yes I had an aluminum driveshaft....
            Then I made it my daily driver and got a 5.0 for racing.
            In fairness I had a lot of track time in my car.... I was snap launching it which is what broke components. I was also full weight.
              i've heard that spec's have a lot of chatter. i went with a centerforce dual friction and it's great. grip hard and doesnt slip
              WAWA-A-HOLIC
                its funny you say that because my input shaft has a ton of play and only 3rd gear whines. on the street the clutch holds most of the time but at the track it was horrible. i didn't even do a burn out and im running 235/55/r16 bs street tires. it was real sticky that day.
                  i was looking at a few ebay stage 2 clutches. i will be rebuilding the T5 when i pull it out.
                    Went with CF DF. It works.
                      My spec 2 had a little nothing that bad. I stated earlier, I would do a new flywheel, to take up any gap from a worn one, to get all you can out of the clutch spring.
                      Ebay clutches? I would avoid anything not namebrand, if you are actually making power.
                      I put an EXEDY in because its a daily driver I just want to get me around, for a few more months then sell.
                        ive been daily driveing my car for 8 months with ac, power steering an all.
                        http://cgi.ebay.com/ebaymotors/F1-RA...item1c1bb5217f
                        i've used this company of clutches before on lt1s and other with mods and have had good luck with there stage 1 and 2. but the stage 2 for a 3.8 camaro from them is rated for 300 flywheel hp. there stage 3 is a bit overkill with 365hp rating but i know it shouldn't slip with my set up.
                          the slippage, I think is also based on spring pressure. Yes it can be rated, but if you are a bit "rough" on your shifts, it may slip then catch kind of deal.
                          With a Spec 2, I experienced some slippage on harsh powershifting.
                            I would go with a Spec 3 it will hold through the gears, just need to watch 3rd gear on your tranny.
