Hi Guys have anyone out there ever use the Energy Suspension Mount 3.1108 on the 3.4V6 with Manual Transmission????
If you so,were they any issues lining up the holes??
You need to notch the trans member to get the hole to allign.
^^yup. Doesn't take long if you have a stepped drill bit. Also make sure you use a spacer to make sure your pinion angle is retained. I used the rubber bits from a sway bar link.
13 hours ago
