I have an A4 98 Camaro v6. Do I need a half inch spacer for the Energy Suspension mount? I installed it awhile back and didn't use one. Just put a used engine in and noticed it vibrates idling in drive but is smooth while driving.
Can't find answer anywhere
Re: Can't find answer anywhere
A piece of rubber would pretty much counteract the whole reason of the energy suspension mount. I went to the hardware store and just grabbed a bunch of washers and stacked them.
Make sure you don't have any loose or broken bolts on your engine mounts.
Look @ the "Stickies" in the Drivetrain Forum.
.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by Kenneth View PostThe link is down and all the spacers are used on 5 spds and a few asked about auto with no response. Does the pinion angle make a vibration when not moving or only when driving?
M5 or A4 doesn't matter. Will work the same.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I would jack it up and take a look.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Check your mount to see if its loose, maybe install a spacer.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
