3.4 compared to 3.8 motor mounts - FirebirdV6.com/CamaroV6.com Message Board
  • 3.4 compared to 3.8 motor mounts
    Trying to see how the 3.4 mounts compare to the 3.8!
    Re: 3.4 compared to 3.8 motor mounts
    Disclaimer: I've never messed with motor mounts
    So what do you want to know? I don't know specifics but both the 3.4 and 3.8 have been in the same chassis. The mounts are sized to fit the motor to the space. They are specific to their respective engines. People who want a more solid feel generally get newer solid rubber mounts or for even firmer feel go the poly mounts (not that I would reccomend poly engine mounts over solid rubber).
    96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
      no Im swappen a 3.4 to a 3.8 just wondering if mounts were the same.
