'97 Firebird. Recently swapped out the differential, gears, and speed ring. I've driven it about 15 miles and the ABS light is still on. Any suggestions?
ABS Light after Differential Swap
Re: ABS Light after Differential Swap
Sure that speed ring went in right (i'm that is what I call the reluctor ring) - abs sensor wire still plugged into pumpkin?96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
Originally posted by cam98aro View Posti seen a cheap obdII/abs code scanner at walmart lastnight08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 weeks ago
