9.75" axle swap - FirebirdV6.com/CamaroV6.com Message Board
9.75" axle swap
  • 9.75" axle swap
    Yes, a Ford axle, from an Expedition. 34-spline, 3.08:1 for me, 5-lug can be re-drilled to the GM lug circle. But I'm ditching the torque arm for a shorter third link on the top right.
    Not leaf-sprung like F150HD, so the bracketry may be useful. I do know that once I press the lug studs out, the outer pilot will have to be lathed down to fit inside 'vette wheels, I'm probably going 17x11. Early versions use smaller outer ( wheel-end ) bearings, which is a good thing for this swap. Having tried to home-drill Explorer axleshafts, I'm guessing these can't be done at home either. But I can get the whole thing for around $150, with the strength of a Strange S60 and the 3.08:1 gears of a Strange 12-bolt, so why not?
    I don't have a rans yet for my 4.8L LSx swap, so a 4L80E means I can turbo with this strong of an axle.
    Re: 9.75" axle swap
    LETZRIDE used a 8.8 rear I believe so you might want to pm him and he can answer your questions. I think he swapped it over to his LS1 from his v6 camaro so he still has it.
      Re: 9.75" axle swap
      Mike had Cam weld a TQ arm provision on it.
        Re: 9.75" axle swap
        Already been down that path, got an 8.8 from an '01 Mustang GT, fabricated a torque arm mount. Also did a Dana 60, that was easier to torque-arm. But Semi-float D60s are rare and not 35-spline, and only go down to 3.54:1, plus they're heavier than the F9.75. D61s can go 3.07:1, but they were never semi-float.
