Transmission removal help!! - FirebirdV6.com/CamaroV6.com Message Board
  • Andy H
    replied
    Thanks! That got it broke loose! I had to put a cheater bar on a ratchet. When it broke loose, I smashed my arm into the floor jack! Oh well, if your not bleeding, you ain't doing it right! Anyway, I was using a 3/8" extension with my impact. I hope I didn't damage the input shaft getting the transmission out. Is there anyway to check? Or, should I just replace it? I'm going to replace the slave cylinder. Anything else I should replace while I'm in there? I've attached some pics of the transmission.
    Leave a comment:
    replied
    You could try PB Blaster, or something similar and just spray them real good and let it sit overnight. I would think an impact would take them out so probably stuck pretty well if that’s not working. Are you using a 1/2” on your 18” extension on your impact?
    Leave a comment:
  • Andy H
    started a topic Transmission removal help!!
    Hey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission in, are the top two 18mm bolts. I have tried everything I know, and nothing is working. Any tips on how to get these broken loose? I have used an 18" extension and an impact, and it will not break loose. Any ideas?
  • Manimal
    Coil springs
    by Manimal
    6 days ago
  • Manimal
    Newby here
    by Manimal
