Transmission removal help!!
I finally got everything put back together! The camaro is back on the road! I drove it to work tonight and it is doing great! I appreciate all the help!
Leave a comment:
Yeah if the stock one didn’t have it and new one doesn’t, probably doesn’t need it.
Leave a comment:
No, it didn't come with the clutch kit. I'm leaning towards installing it without the shim.
Leave a comment:
To tell you the truth, I don’t remember using a shim. Did it come with the clutch kit?
Leave a comment:
I got the correct pilot bushing and got it installed. I had my flywheel machined and got it back yesterday. I was going to install it today but, I was wondering if I really need a flywheel shim? I didn't realize that I might need one until I was looking at installation procedures. What do you all think? Is it necessary to install the shim since I had my flywheel machined?
Leave a comment:
Yes ,you need the correct one, might return it, or see if you can find a A/C Delco one. I use to use the ACdelco ones with my Spec clutches ,some of them come in plastic not metal so stuck with stock ones.
Leave a comment:
Leave a comment:
Looking at rock auto, I may go with either Luk or Sachs. I wish the centerforce kit was cheaper. I need to get the slave cylinder and release bearing as well.
Leave a comment:
Centerforce Dual Friction Clutch Kit is $430 - I have the Centerforce I Kit - but you can't get the disc anymore.
https://www.centerforce.com/search.h...+%28231+cid%29
Leave a comment:
Looking at clutches Duralast is about $100 and Ram clutches are little over $400 so will be up to you money wise on what you want to spend.
Leave a comment:
Wow, not bad getting that many miles out of it. lol , I used Spec clutches when I was M5 but don’t know if there still around. I’d see what the Auto stores are selling for replacement. I know Robert, FirebirdGT has a M5 so maybe he can chime in and see what he recommends.
Leave a comment:
All the parts are the original ones except for the ripper. I haven't decided on which clutch kit yet. I definitely have to replace the slave cylinder, and I believe the throw-out bearing was making noise. The car has got around 130,000 miles on it. I just need something similar to oem and not too expensive.
Leave a comment:
Nice, yeah just looked at the input shaft if it doesn’t look bad I wouldn’t worry about it. For replacing stuff, how old are the parts. Like TOB . Which clutch did you go with?I see you have a B&M Ripper, when I was a M5 that’s what I had, one of the best mods for a M5.Last edited by ssms5411; 10-20-2024, 08:52 AM.
Leave a comment:
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....1 day ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.1 day ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
Leave a comment:
