trans leak... - FirebirdV6.com/CamaroV6.com Message Board
trans leak...
  • trans leak...
    A friend of mine has a 99 Z28 that is leaking trans fluid from the front of the car. I helped him replace the B&M Trans cooler recently, and that has taken care of about 90% of the leak. But there is still a leak in the front of the car. all hoses to the trans cooler are tight and the hoses are new. I am beginning to suspect the radiator is leaking?!
    OK. so Heres my question:
    I know coolant goes through the radiator... but so does trans fluid? Does the trans fuild go through a different radiator? It looks like there are 2 radiators up front...
    any suggestions or comments?
    *OneQuickSix*<br />1998 3.8L V-6 Camaro<br />~A4 w/Y87~
    I'm pretty sure in a tranny cooler, it is tranny fluid in the radiator. The engine itself uses coolent, because that flows though the block, cooling it. With a tranny cooler, the fluid from the tranny flows though the radiator/cooler, let it bleed of its heat that way.
    So in short, yes, I'm pretty sure the fluid does go through the tranny cooler radiator.
    1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
      yeah, it does
