i've had this annoying first gear acceleration only whine lately, and i assumed it be in the differential.
well, i talked to some pro's on the matter, they told me to put some thicker gear oil in the rear and that the zexel torsen, does in fact, need lsd additive.
so i pulled my axle housing cover off and looked at all the teeth i could see (even turning the driveshaft a couple of times to try and view all of them) and i saw no signs at all of wear in them. also, there were NO metal shavings or pieces attached to the magnet within the housing.
i put some gasket sealer around the housing cover, put the gasket on the sealer, then put the housing cover on and tightened it up pretty tight.
i then added the lsd additive, and that was followed by the 80W 140 gear oil...but guess what? the noise is still there... hrmm, i don't know what the answer is.
but, all the teeth looked good from what i could tell and as well, there were no metal scraplings in that housing that i could see (which is pretty odd, cause most housings have a bit of shavings). all in all, i'm happy that i think my rear end is in good shape.
however, i still can't find the damn whine!!!!
please, does anyone have any guess at what it may be? it seems to only be there in above 2k rpm's and below 3k rpms in first gear acceleration only; if i put SGS on, i can't hear it, and it's no where else but that first gear.
please help me, arg...
[ January 05, 2003: Message edited by: Only4U ]</p>
