2nd gear start - FirebirdV6.com/CamaroV6.com Message Board
2nd gear start
  • 2nd gear start
    is it bad if i use 2nd geat start a lot? it's been raining and snowing a lot lately here in jersey and i use the 2nd gear start button a lot
    just wondering if it causes any harm to the car from using it so much
    mcG<br />aim=endlive<br /><a href=\"http://www.cardomain.com/id/endlive\" target=\"_blank\">97 firebird</a> ~ wrecked
    nope, just higher in the powerband is all. now if you used everytime you started for 100K miles, then you might see some difference.
    Not a problem, just a challenge...
      Another problem that I could see with doing this is if you find yourself bending into the clutch so that it doesn't stall then you would be wearing out your clutch faster but if you aren't doing that then there should be no problem with it.
      1998 V6 m5<br />ram air mod<br />(the sc is for south carolina not super charged but maybe that will change)<p>\"Thank the Lord for air tools\"
        NJ has been geting pounded, I hate the snow!
        Anyway, I have the same concern, I use it if I am on ice or snow so maybe 6 times this winter already.
        ~chris~ 98 Cayenne red Camaro 3800 A4, 3:08, T tops Borla cat-back, wisper lid K&N, Bilstine shocks, Dunlops all around. <br />AOL IM: chevyboyz24
          i love that button- sounds soooo good to be in a parking garage, put the windows down and just give it 50% gas---sounds sooooo V8
          98 Jeep Grand Cherokee 5.9 Limited<br /><br /><br />MODS:<br />180* t-stat, K&N FIPK, mopar ECU,<br />mike leach long tube headers+3\" y-pipe, 3\" all the way out flowmaster 50 series, mopar magnum 2bbl m1 intake manifold, APS 52mm throttle body, powerslots, 2 JL 10w3\'s
            technically, yes it does harm the tranny because the tranny is heating up more because you're eliminating 1st gear and going straight to second gear. Atleast someone told me that [img]tongue.gif[/img]
              <blockquote>quote:</font><hr>Originally posted by Tri-Flo 99:
              i love that button- sounds soooo good to be in a parking garage, put the windows down and just give it 50% gas---sounds sooooo V8<hr></blockquote>
              [img]graemlins/rofl.gif[/img]
              but the power output it gives in return will remind you that it's just a V6! ;)
                its not going to hurt you car, tranny or anything else. its there as a safety device. to help avoid spinning. it **might** cause a little more heat in the tranny but nothing that will make any difference. even with no tranny cooler the stock trans doesnt hit that high of temps. and me and my 3500 vigi never get over 180 or so. i [img]graemlins/love.gif[/img] my tranny cooler
