Today I was doing a burnout and only one wheel was spinning. I have the Y87 package so my car came with LSD stock. I havent done a burnout for a while and last time I did it, I'm pretty sure I spun both wheels. I thought my LSD is busted but is it even possible to break one of them? Whats the symptoms of a broken LSD?
Is my LSD broken?
Repeat your test and see if you get the same result. If so, the carrier is shot. That is the most common way for a rear to go though, much better than fragging completely because then you have limited time to get a new rear.
g2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
What do you mean by repeating my test? Should I do a burnout again or is there a better way to find out?1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
