RPO codes found in you glovebox, in the centerconsole or inside your doorjam.
Gu4-3.08
GU5-3.23
GU6-3.42
G80-factory Limited slip differential.
Auto Y87s came with both 3.42s and LSD
5-speed Y87 came with 3.23s and LSD
all auto and manual 3.4L v6s 93-95 came with 3.23s
5-speed 3.8Ls came wth 3.23s
Most non-y87 auto 3.8Ls came with 3.08s
Some non-y87 auto 3.8Ls came with 3.42s(mainly newr 3.8Ls)
someone add when the 3.8L switched form 2-piece driveshaft to a 1 piece steel, then we should stickeefy this post.
