When I shift into second at a high RPM the trannie grinds, it only happens going into second. Would this be bad synchros?
Grinding in second
Bad master cylinder.
Check if the fluid is clean, if not replace the master.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Oh yay... It started after I blew out my old trannie and had a new one installed about a year ago. When I took it back to the place and told them about it, they just told me not to drive it as hard.1997 Camaro RS<br />--------------------<br />K&N CAI<br />2 1/2 inch dual Borla<br />Bosch Platinum +4 Plugs
lol they didn't lubricate it well enough when they put it in. They should have usd some silicon based oil when replacing the gears. Check back with them.Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Answer: Yes1995 Camaro M5 3.4 Quasar Blue Metallic with T-tops.<br />K&N, Jet Stage II chip, Z28 exhaust, 1LE aluminum ds. Need more power!<br />Next: Auburn posi<br />1976 Pontiac Trans Am. Street driven. Has low compression 350 Chevy runs 12.81 @ 104, 1.73 60\'
