where is it? anyone have a picture?
LSD location
The differential is in the rear end. It carries the ring gear and the axles connect to it.Matt
1998 Mystic Teal Camaro M5
Dave:
00 Supercharged Camaro - RIP
97 Turbo Camaro - Sold
Hard to tell from that pic, but it could possibly be the seal where the pinion gear connects to the drivesahft.
Also, check out: http://auto.howstuffworks.com/differential.htmMatt
but like ssaid hard to tell..-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Mine looks like that but it doesn't leak. It's from a while ago when it did leak. It's just like stained now.\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
Originally posted by dmw319:
mine is def. seeping something, its all gross and grimey. idk if its the LSD leaking or what..\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
Just go to a local auto parts store, should be no more than like $5. Just gotta pop the 10 bolts off the diff cover (have an oil pan or something ready to get the gear oil that will pour out all over), scrape the old gasket off (whats left of it), put the new gasket on and bolt the cover back on, and finally refill the diff with gear oil (there's a little plug at the top where you pour the gear oil in). You should only need about 2-2.5 quarts/bottles of gear oil.
p.s. gear oil stinks like sh!t\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
