What's the Difference... - FirebirdV6.com/CamaroV6.com Message Board
  • What's the Difference...
    ...between a reluctor ring and a ring gear spacer? Do I need one or both?
    I have a 1998 3.8 A4 with 3.08 gears (series 2, right?). I'm buying a Series 3 LSD and 3.73s.
    What will take me from series 2 to 3 for the LSD to work?
    A spacer is to let you run a series 3 gear on a series 2 differential.
    The ABS reluctor ring goes around the outside of the diff for ABS brakes.
    You're getting a new diff and gears, so you don't need the spacer. You do, however, need the reluctor ring for a series 3 diffy (get it from SLP).
    Matt
    1998 Mystic Teal Camaro M5
      Thank you, sir.
      You guys sure are coming through for me with good info the last couple days. Thanks.
