me and my uncle( who is a mechanic) put my new clutch in...but we forgot to put back the transmission oil. i want to drive my car, but i need to know where to put the transmission oil...can someone help?
transmission oil..
Passenger side of the transmission, there is a plug you will need to unscrew with a 3/8" ratchet drive. Put the fluid in there. I use a pump that I got at PepBoys for about $9.00, but you can use a bottle also. Fill the bottle with Dextron III and squeeze it into the filler hole. Fill until the fluid just begins to drip out of the hole, then plug it up.
** Try to get the car as level as possible when doing this.
-Marcsigpic
