Does any 1 know what it does or helps with?
Clutch trouble
<a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
there is a restriction in the line put there from what i believe to makeit so the clutch doesn't grab so hard.
The restriction slows the fluid to return back to the clutch when you let it out.
I guess sort of like "torque management" on autos, except its a mechanical thing vs. a computer controled thing [img]smile.gif[/img]-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
ahh i c...I bleed the clutch a few times and it still sticks so I guess im going to replace the clutch master this weekend.
Thanks alot for your help [img]smile.gif[/img]<a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
np seems when you get in teh nitty gritty of clutch stuff seems like there are fewer and fewer people that offer help.
Just hope I helped out a bit.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
just a heads up, eric is right. that stupid U bolt is gonna take 99% of your time. me being 14 with small hands had trouble, mostly because you cant really see anything. do the drill mod, you already have a new master cylinder. i wish i knew about the drill mod before i changed mine. good luck. me and eric both changed ours pretty recently, so any more questions im sure one of us can give you a answer.
BTW i got my master cylinder at advanced auto for $901998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
