I finally found out that my rear caliper squeak is a bent axleshaft. I need one quick cuz this squeak is annoying me! So my question is what axles will fit my 95 3.4? My guess is since the rear ends were basically the same for 3rd and 4th gen, wouldn't the axleshafts be the same too?
Axleshaft Compatibility
No, 3rd Gen axles are shorter (the whole rear is more narrow than a 4th Gen)
You have the rear drums, right? I saved the axle shafts out of my stock rear. Should fit perfectly on yours.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
ok so are 4th gen shafts compatible? and no i used to have drums, but now i have discs. i was told that theres no difference except that the disc axles are stronger. so if you still have an axleshaft...would you be willing to separate the pair?<b>1995 Bright Red 3.4L</b> <br /><a href=\"http://www.cardomain.com/id/94camaroguy\" target=\"_blank\">Carmen\'s Page</a>
The only difference I'm aware of in 4th Gen axles is traction control vs. non-traction control. TCS axles have the sensors.
And sure, one is fine. Email me at funkz@comcast.net1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...15 hours ago
