95 V6 rearend to 98SS rearend - FirebirdV6.com/CamaroV6.com Message Board
  • 95 V6 rearend to 98SS rearend
    trying to work out all the bugs, has anyone done this? will the SS have traction control and prevent me from swapping rearends??
    do all the brake lines still work??
    did you swap the proportioning valve or is it the same?
    91 Mustang LX 2.3 Turbo - T5<br />-daily driver, 210hp/300ft-lbs (outdated)<br />94 Ranger Splash 2.3 Turbo - T5<br />-serious build up, shooting for 400+hp<br />95 Camaro 3.4 auto -hers<br />-she\'s workin on it
    It's not the TC but the ABS you will have a problem with. Your car has a single rear ABS sensor in the rear end. Most 98+ have two at the wheel. The ABS is a different manufacturer 93-97 and 98+. It can be done but it is not a "bolt-in".
    Raven
      what needs to be done??
        Let's start with - why do you want a 98 SS rear end?
        Raven
          Probably for the gears and LSD would be my guess. The 98 SS part I would say he prob. has one locally he can get if it works. [img]graemlins/wavey.gif[/img]
          http://www.bowtiev6.com/
            gears, posi, disc brakes, the big ones, oh and we're getting that, front and rear sway bars, and the larger front brakes (with new rotors and pads) for.....
            drumroll
            $575 locally
            why wouldnt we want that
              forget the suspension for now, i see you have 11.5" rear rotors, what did you use?
                93-97 rear disc brake "kit". The stock V8 rear.
                http://www.tacreationsusa.com/suspensi.htm
                Raven
                  talked to russ about it and he thinks it should be ok (the rearend doesnt have traction control btw) but i may have to change out the reluctor ring??
                    No you don't have to change out the ring. Rears either have single or dual channel ABS, that's it. And putting a dual-channel ABS rear on a single-channel car is not impossible, it's just not plug-n-play.
                      i went and looked at the SS rear and it had a single hose leading to the T in the hardlines
                      so will it work?
                        Yeah, that should be identical to yours.
                          yaaaaay
                          thanks guys
                            so V8 Fbodies have larger rear brakes than the v6s?
                            Cardomain&gt; <a href=\"http://www.cardomain.com/id/7camaro7\" target=\"_blank\">http://www.cardomain.com/id/7camaro7</a> <br />CarSponsorships.com&gt; <a href=\"http://www.carsponsorships.com/scout/sponsor.php?id=2358\"&gt;\" target=\"_blank\">http://www.carsponsorships.com/scout/sponsor.php?id=2358\"&gt;</a> <br />Webmaster\'s Earn Money Here&gt; <a href=\"http://www.carsponsorships.com/scout/index.php?ref=2358\"&gt;\" target=\"_blank\">http://www.carsponsorships.com/scout/index.php?ref=2358\"&gt;</a>
                              No. But not all 97- V6s came with rear disc brakes.
                              97- V6s had smaller rotors than 98+, but in the same year the size is the same.
                              Rear rotors:
                              93-97: 11.5"
                              98+: 12"
                              Front rotors:
                              93-97: 10.9"
                              98+: 11.9"
                              Matt
                              1998 Mystic Teal Camaro M5
