It's not the TC but the ABS you will have a problem with. Your car has a single rear ABS sensor in the rear end. Most 98+ have two at the wheel. The ABS is a different manufacturer 93-97 and 98+. It can be done but it is not a "bolt-in".
Originally posted by FirebirdGT: Let's start with - why do you want a 98 SS rear end?
Probably for the gears and LSD would be my guess. The 98 SS part I would say he prob. has one locally he can get if it works. [img]graemlins/wavey.gif[/img]
gears, posi, disc brakes, the big ones, oh and we're getting that, front and rear sway bars, and the larger front brakes (with new rotors and pads) for.....
drumroll
$575 locally
why wouldnt we want that
91 Mustang LX 2.3 Turbo - T5<br />-daily driver, 210hp/300ft-lbs (outdated)<br />94 Ranger Splash 2.3 Turbo - T5<br />-serious build up, shooting for 400+hp<br />95 Camaro 3.4 auto -hers<br />-she\'s workin on it
No you don't have to change out the ring. Rears either have single or dual channel ABS, that's it. And putting a dual-channel ABS rear on a single-channel car is not impossible, it's just not plug-n-play.
