May be a dumb suggestion, but, make sure you have an alignment tool when doing this. You'll be under there forever trying to get the trans shaft to match up with the pressure plate/disk if you don't.
You should also replace the pilot bushing and get the flywheel resurfaced while you have it all apart.
just remove the mount/ x member first and let the tranny hang so that you can use a very long extention and swival to remove the top belhousing bolts. Then suport the tranny and pull the rest. RWD trannys are rather simple.
I did it in my garage. The transmission only weighs about 65 lbs. The new clutch should come with an alignment tool.
1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
Originally posted by malice10985: I did it in my garage. The transmission only weighs about 65 lbs. The new clutch should come with an alignment tool.
How exactly did you do it?
Can I use 4 ramps instead of stands? I don't feel comfortable getting under the car when it's on stands. I might get rails from somewhere though as a precaution in case stands fail.
Basically all you gotta do is take off the tranny and replace the clutch and bearing? How long did it take you?
Originally posted by ka50: </font><blockquote>quote:</font><hr />Originally posted by malice10985: I did it in my garage. The transmission only weighs about 65 lbs. The new clutch should come with an alignment tool.
Basically all you gotta do is take off the tranny and replace the clutch and bearing? How long did it take you? </font>[/QUOTE]you should take the fly wheel off and have it re-surfaced...... its about $20-$40 but worth it IMO.
yeah you can use 4 ramps
you need a bearing puller
and i would replce your slave cylender while the tranny is out..
your goign to need brake fluid to bleed the clutch after install.
im doign the same thing.. i have all the parts already.. just miss'n the fluid. whats a good lubricant for the transmission? something good that i can pick up at the local parts store. i was thinking about going to synthetic. that, and how much of it do i need?
96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
Originally posted by Tyler: im doign the same thing.. i have all the parts already.. just miss'n the fluid. whats a good lubricant for the transmission? something good that i can pick up at the local parts store. i was thinking about going to synthetic. that, and how much of it do i need?
I used castrol syntec Dexron, i think it took 3-4 quarts. It says in your owners manual. Also, i'd suggest filling it up through the shifter hole in the top of the tranny, it makes it way easier.
I trust stands more than ramps, plus they give you a lot more room on the ground, and you can get the car higher in the air, which every inch higher you can get the car, the easier it is on you.
It would suck to have the tranny dropped, only to find out the car isn't high enough to slide it out.
From experience, it is easy to put a jack under the tranny from the front of the car drop the tranny, and pull it out from the front. Put it back in the same way.
1997 Dodge Viper GTS
I am gong to us Mobil 1 tranny fluid, it was pricey though, like $4-5 an bottle. I forgot the exact capacity but double check the owners manual IM me or ask here if you need the exact amount.
As for filling it up, I bought a suction gun, it holds a quart, basically works like a giant syringe, suck the fluid up, push it out in the tranny.
I've not separated my recently bought engine/tranny from each other in the garage yet, but I know that with the small blocks, there was no bearing in the flywheel, just a copper bushing. You don't need a puller necessarily, if you fill the hole in the bushing where the imput shaft goes with grease, put a dowel partially in the hole, then tap at it with a hammer, the hydraulic force in the hole should push it out. Same should go for even a small bearing in there....give it a shot....
~Tom
1994 Camaro: Firebird Interior, 3.4L to 3800 converted, OBD2 converted, A4 to M5 converted...In the turbo retirement home...<br /><br />1994 Mustang GT: 347 Forged Stroker, Port Matched Edelbrock Heads and Intakes, Tremec 3550 T-5, Spec Stage 2
did u get it done yet? how did it go? how long did it take?
